Motor Stands
imported_Mo_Tick
Hello again, i was thinking of getting a Motor stand, but was wondering if i could go to a pawn shop and buy a simple Dolly (2 wheeler)add a piece of wood and use that..<br /><br />are there any other cheap solutions or ideas?
JB
Re: Motor Stands
Depends on the motor, Mo.<br /><br />I have done that with engines up to about 150lb with heavy duty dollys, but wouldn't recommend it above that. I also would not recommend it with a cheap, simple dolly for anything over about 75lb.
tashasdaddy
Re: Motor Stands
i being a master carpenter by trade for over 35 years, do not like wooden motor stands, screws pull loose, bolts wobble, i like using aluminum angle and bolting it together. there's just to much stress and vibration when rolling the around. i can make almost anything out of wood, but i don't like wooden stands.
dajohnson53
Re: Motor Stands
I messed around with trying to make due, and then I bought a carrier from Cabelas for around $50 OR $60 - Really, it's very nice, solid and so convenient compared to what I had cobbled together. It was well worth it.
tashasdaddy
Re: Motor Stands
agree with D. you can spend that much trying to build one.
joaklay
Re: Motor Stands
I have several aluminum Garelick stands that I've purchased from an online Marine dealer found via google BUT if you've got any that are on the heavy side, over 130 lbs (like my '59 Merc Mark 58A), I'd then advise a metal stand as I've found that the aluminum can bend even though it's rated for that.<br /> The metal stands are often sold by a guy on Ebay for about $50 which is reasonable.
