Hi guys, I am having an issue with my control box or the throttle cable. I have a 70 H.P Johnson outboard, 1982 model year. Runs fantastic. Has a cold start lever on the control box and one lever for gas and hears (F, N, R) Lately, the cold start lever is coming up when I throttle back off the gas to put it in neutral. I have to push that lever back down before I put her in neutral or it will be too many RPM's in neutral. Control box is an OMC model
Now, the situation got worse today. I took the box apart and greased everything up and tightened the loose screws and such. Everything went back together as it was, no problem. But now, I can give it gas with no problems at all. The throttle on the motor is moving giving the motor more gas, however, when I pull back on the throttle lever now, the throttle on the motor will not go back. It will move ok if I move the throttle linkage with my hand at the motor, but not with the cable from the throttle handle. It happens every time now when I give it the gas, and that cold start lever is still popping up. I can push it back down before I put her in neutral, yet the throttle is stuck at the motor pretty high RPM's until I again close the throttle with my hand at the motor. The cables are only two years old. What can the problem be? Thanks!
