cat toon
- Joined
- Sep 20, 2010
- 61
Completed the first run of the motor after I replaced all the gauges that did not work,the tach worked great,the trim meter worked,the temp gauged looked to me it started to rise but did not run the motor long enough to check it propertly,the volt meter to the main Battery worked showed the battery was being charged,the water pressure did not work but water was coming out the pee hole,must have it plumed wronged.
