Yammerhead
- Joined
- Mar 29, 2008
- 15
I have a 75 fiberglass tri-hull that has had an 85HP Evinrude on it since it was new. I have taken it off and am going to put a 73, 85HP Merc on. Is there anything I need to worry about before I go and re-drill the transom? I assume that as long as I center the new holes in respect to the existing ones, it should be in the correct position? There are quite a few mounting tabs on the Merc to choose from. Which ones are the best to use? Is there such thing as a template for the mounting holes? Is there anything else a guy should be worrying about?
What's the best way to seal up the old bolt holes? RTV sealant or ???
Any advice is appreciated.
Thanks!
Thanks!
