Motor swap
bustedblock
Hello,
I am running a 93 200 EFI on my boat, the motor is blown and I need to know if I can swap out with a 97 200 EFI without any wiring changes?
Bifflefan
Re: Motor swap
Hello,
Are you talking a complete motor swap? Intake and all?
I dont have any idea.
If your just talking the long block, then you probably can.
Faztbullet
Re: Motor swap
Should be a straight up install, make sure you flush/drain VST tank of old fuel before starting.
Faztbullet
Re: Motor swap
Vapor separater tank, #10 is drain screw.
