My 93 200 Johnson will bounce on the last 50% of travel down in the TILT mode. Trim is fine. Tilt up is good. I have the OEM manual and the travel time is within specs. I'm worried about my transom
Here is what I have done. Greased the bejeebers out of the two grease fittings on the tilt tube. Backed off and retorqued the nuts to spec and backed off the starboard nut 1/4 turn.
Raised all the way and topped off the hydraulic to the top and repeated the up and down maybe a couple of time filling up the the oil to overflow. (GM Dexron II)
I noticed first time I did the fill thing it spit out a little fluid which looked to me "aerated" like lower unit oil when it gets air into it. Milky looking.
It seems that when I do all the above in the workshop it fixes it. I go the lake, try to catch some fish, (bad year) and come home it starts acting up again.
Is it an air in system issue? If so how do I drain and replenish the fluid or am I missing something.
Thanks in advance.
Thanks in advance.
