Motor Tilt
U68423
Hello all, quick question. How far can you tilt a motor up before it will do damage to the motor. I have a 1989 Bayliner 19' with a 125 HP Force. The reason I ask is the water level on my lake is going down and at my dock I have about 2 1/2 - 3' depth so as I back out I raise the trim all the way up and then also a little tilt, prop still in water but the exauhst is very noisy at this point. So that said how much is to far?
catfish1
Re: Motor Tilt
as long as your pumping water(out the peehole) its ok!
U68423
Re: Motor Tilt
Hey Catfish, with my motor Force it's more like a spray. So as long as it sprays it's ok ? Even if the prop comes out a little bit ?
catfish1
Re: Motor Tilt
let me rephrase: as long as the water pump is pumping water.
