Motor tore down burnt piston??? Help??
acuraguy81
I got my motor tore apart heads off and they are going to the machine shop. but I have a piston that is toasted has chucks of the ring on top of it burt good from when the motor got hot. the cylinder walls seem to feel ok. Im going to pull the motor completely out and change the one piston and all the rings and bearings while the block is out and reassemble. any thoughts?
1990 4.3 omc
Re: Motor tore down burnt piston??? Help??
1990 4.3 omc
Ayuh,.... The above is covered Here....
No need for multipule threads on the Same Problem...
acuraguy81
Where is the best place tp buy parts for the rebuild? Also im going to replace the hydrolic rollers too.
