Anyone know where I can get a set of outboard motor trim shims or something that can easily be made/used as a set. I've got 2 trim positions on my motor that both get me on plane. One cruises real good in a straight line but cavitates the hell out of the prop in a tight turn, the other pushes down on the bow especially with weight in the front and the cavitation plate is not quite parallel with the bottom of the hull. I'm guessing a spot somewhere inbetween the two would be the best solution but the only thing I can think of is some kind of shim
