BigNiner19
- Joined
- Jul 1, 2006
- 234
I knew it was to good to be true. After the rebuild I've put probably 100 hours+ on the motor. Motor still runs, and I dont think anything severe is wrong with it. But its struggling at idle, running pretty rough, even with a little vibration. This is in gear at idle or in nuetral.
But once you give it some gas and get it up on plane, it runs great and the motor sounds like it always did before. Why does it sound so bad at low RPM's?
I put it on the hose, and I was actually able to hear it miss pretty frequently while idling on the hose. Do I need to rebuild the carbs? Could something else be wrong?
Cory
Cory
