Hi guys,
I have a 75 H.P Evinrude, 1965 model # 75553 Speedi-four motor. I just picked this motor up with a boat and trailer. I had problems with it overheating when I first bought it. I have had that repaired and it is ok now. The motor starts and runs fine, however, it seems like it uses a hell of a lot of gas. Yesterday I went out fishing, and I went out about two miles, not WOT either. I pulled back on the throttle once I planed and just cruised and about 2/3 throttle. I moved around a bit while out there, but only short runs and not far at all. I came back in and used 3 and 1/2 gallons of gas for the approx. 5-6 miles I drove around. This seems like a lot of gas to me. Is it?? I have a 16 ft fiberglass boat. Its a 1965 Geneva.
I read on another section of this forum that one guy replaced his diaphragm in his fuel pump because he was using a large amount of gas. After he replaced this diaphragm, his motor used much less gas compared to what it was using. Is this possible for a bad diaphragm in a fuel pump to cause excess gas usage??? The parts are still available for the fuel pump repair kit for $30. It is really a cheap fix if it helps. Any thoughts on this?? Thanks!
