motor vibration at idle not in gear
procraftmark
I have a 89 50hp force that seems to vibrate more than any other motor i have had , it is not brutal but more than i would think it would be at idle. Motor is in good shape and pops right off after you start her the first time of the day.
any ideas
mark
steelespike
Re: motor vibration at idle not in gear
Just a thought I wonder if one of the mount cushions is broken or damaged?
There is an idle mixture screw maybe you need to adjust it.Initial setting is 1 turn out from gently bottomed.Then adjust with the motor warm in gear.Always leave it slightly toward rich.But not enough to affect the idle.
