Motor won’t turn off
Award
Hey all long time sense I’ve been on here
my 78 800 merc runs great after rebuild but won’t turn off with key I have a Sierra 41000 ignition
i read an old blog on how to hook switch up
havnt done it that way yet should hooking it up that way solve my problem
Chris1956
Your motor should have a 4 coil ADI ignition. To kill the ignition, the orange wire should be grounded at the ignition switch.
If the motor is older than 1976, it should have a battery powered CDI ignition with a distributor and one coil. To kill ignition on that style, the white wire is disconnected from battery power at the ignition switch.
What do you have?
Award
4 coils I did try and ground it on switch but didn’t work I left old choke I think I need to bypass it and go to push to choke on new switch I’m not sure what the white does if anything I did ohm out harness all check good everything is new on power head
Chris1956
The white wire on your motor powers the tachometer and the choke solenoid. That is all
Award
I had a ground issue had to move my bonding strap works like a charm
