I have a 1981 Evinrude 75 hp, I am experiencing intermitting cranking problems, sometimes the motor will not crank at all, there is no clicking sounds at the solenoid or the starter, it's like there is no battery connected, but if I wait a few minutes (say 5 min) it will crank just fine for the next several times then later it will not crank at all until I let it set for a few minutes then it will crank over. I have checked all the connections for the starter etc. and all of them are tight and do not have any corrosion. I have replaced the ignition switch but that didn't cure the problem. I have checked the neutral safety switch and it seems to be functioning fine. Any suggestions as to what may the problem would be appreciated.
