2002 Mercruiser 5.0 MPI 260 alpha 1 gen 2. A couple of years ago one of the tabs that holds a screw for dist cap broke so I used flat washers to secure cap. All good until the motor started misfiring at high rpm over the weekend. Idled fine and ok at low speed and I made it back to dock. When I checked things I saw the cap lifted up so I figured I would change the cap since I used an automotive cap when in a hurry to winterize at end of season. When I cranked motor it sounded like the wires were crossed and motor would not crank. Made a loud sound like the motor was locking up and it ruined the drive on the starter. I have changed many caps and did one wire at a time. Triple checked and all is correct. Is is possible that when motor was misfiring that the motor loaded up with gas and even though it idled that the motor is locking up?
