Motor won't kick in
cs28461
1992 88 hp Johnson. Motor will turn over and over and will not kick in. Positive connection on the battery started smoking after about 30 seconds of trying to start...stop...start....stop.
tashasdaddy
Re: Motor won't kick in
smoke means bad, dirty connections.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
