OK, this isn't the worst problem to have!<br />Motor is a 1988 115 Yamaha. I started it for the first time in a few months and had trouble getting it to fire up until I thought to mess around with the kill switch, I took the clip out and pulled it all the way out, and it started right up. I let it run for a few minutes and tried to shut it off, it kept running. After several more attempts to shut it off I turned it quickly to the start position, starter hit the flywheel and shut it off. I know that can't be good, but it worked. I started and shut it down 4 or 5 times afterwards and it worked fine.<br />Do I have a short or what? And if this happens again what is the best way to shut it down?
