I have a 87/88 Johnson 88 SPL o/b that will not start after it has been running. When I try the motor a few days later it starts right up without problem. When it will not start there is no spark. The fuel systems is fine, all the electrical connections, ecspecially grounds were checked, the kill switch and neuteral switch checked ok. Is it one of the power packs or temp sensor. Any suggestions? This motor has two power packs, can both be bad or is the a common denominator between the two like a switch or sensor?
