Motor Wont Start
Kjeremy2
I bought a boat motor was rebuilt im new to boating and would like to know how to check all fluids and how to determine why my motor wont start. i have a mercruiser 3.0 and alpha 1 drive thanks alot :D
Re: Motor Wont Start
Howdy, The size and the alpha drive is a good start but could also use the year of the engine and if it is carb or EFI. The engine serial number is best. Could also use what it is actually doing, cranks but won't fire, won't crank (turnover), etc.
To start off with I would suggest going to the top of this section in the Adults Only section and look at number 6 first and if need be number 8. There is also a Mercruiser section for a lot more info on what if's and links to service manuals.
http://forums.iboats.com/mercruiser...tdrives/adults-only-no-exceptions-288430.html
84EdH
K, your other thread said you needed a water pump? Outdrive water pump or engine? Also, if temps are in the 20's at night as you said in other post, if your boat is outside, you need to be sure the water is out of your engine and manifold. You should also drain the outdrive of oil in case any water in outdrive. If the oil is clean, without any milky looking residue, refill with Mercruiser high performance gear lube. As mentioned, go to the adults only section of this forum and read about mercruiser, winterizing etc.
Also, look in Adult only section for where to find the engine serial number and drive serial number and post it. If you try and start engine without water to outdrive if your impeller is not bad now, it will be!
Once we have your numbers we can help with start problem.
84EdH
Dodge I just posted over you.hmm:facepalm:
NOOOOOOO, say it aint SOOOOOOO, I don't see how that could happen, I've only done it more times then I can count. :D it's all good :)
Ayuh,.... I've been doin' the over/ under thing with AllDodge for awhile now,....
Not nearly as often as Don, 'n I, but commonly enough,....
Darn Good answers from Both of ya for Kjeremy2 too,....
Welcome Aboard Kjeremy2,.... Get the info mentioned above, 'n We can be more specific for ya,...
Don'S Adults Only section is a Treasure Trove of valuable Great Info for anybody wantin' to learn 'bout wrenchin' on boats,...
There's literally Weeks of Great learnin' in there,...
Kjeremy2
Thanks Guys i bought this boat yesterday and the guy had said it needed an out drive water pump. i was looking around and a bunch of wires arent connected so im going to try and do some searching as to where they go. the serial number on the engine and outdrive stickers have warn off is there any other places to find them? sorry im such a beginner but thanks for helping me :D
No problem, and serial number location info is also in Don's Adults only section, and the Merc section. Here is a quick link
http://forums.iboats.com/non-repair...engine-serial-numbers-630103.html#post4398826
Kjeremy2
Transom assembly # 0C382348
Drive Serial # 3252209
Thanks Again
Also the guy said the rebuilt engine hasnt been run in the water this past summer so no traces of water should be in it correct? this weekend im going to give it an oil change and go from there and hope i can get her running before april :D
Thanks Again
Your transom serial number "0C382348" is the outdrive drive serial number. Could still use the engine S/N unless the other number you listed is the one taken from the starter. If this is the case you may have a repower.
A trace of water may be found if that, but that should be about all
Thanks Again
Ayuh,.... Pull the drain plugs to be Sure,...
Kjeremy2
The first number i got off the right side rear of the motor and the second i got off the upper unit of the outdrive.
UNSUREBOATGUY
Please pull the drain plugs like Bondo said! At least for the sake of us out here in forum land :)
84EdH
yes, if the engine was run on muffs, or a garden hose right into the intake hose, it has water in the block, and manifolds......if it was run briefly without water, there will be little. as above^.......pull the plugs!
Kjeremy2
alright ill do that today when i find them..... also the motor wont turn over but i will crank so ik its not seized.
jcbache
Might as well get this out of the way... cranking and turning over are the same thing> turn the key and the starter makes the engine spin. Firing, hitting, almost starting, starting , running, etcc is when the engine actually has something ( hopefully a fuel/air mixture) igniting in the cylinders.
Kjeremy2
i found a number on the block and its GM 2770087 is this the serial number?
Nope,... My guess is it's a GM castin' number,....
the number yer lookin' for is stamped into an aluminum tag,...
If ya can't find the number, post a few pictures of the motor,...
We're lookin' for which ignition ya got to narrow down the Vintage,...
Kjeremy2
Here are some photos i hope you can help me narrow this down and how would i go and get a water pick up pump with the drive serial number correct?
