Motor wont stay running
Alex1342
Got a motor that won't stay running.
Cut it down to a fuel issue.
Pulled the carbs and did a rebuild.
Started it up and it ran longer than my initial test.
But eventually you could tell the that motor was about to die.
It started picking up in RPMs then put put....dead.
I opened up the drain valves and absolutely no fuel drain.
Ideas anybody?
1946Zephyr
Re: Motor wont stay running
Model and serial number of engine?:confused:
It's likely a fuel pump issue or a line is plugged. You could even have a leak in the fuel line and it's suckin air.:cool:
tashasdaddy
WHAT MOTOR? YEAR? HP? the speeding up, is running lean just before quitting. does sound like fuel problem.
Alex1342
2003 Johnson 55hp Military Outboard. J55MLSTS
Before I pulled out the carbs, I ran the motor and pumped the fuel bulb. motor still died. Next I kept choking the motor and it stayed running so I went ahead and did a carb rebuild. Could it still be a fuel pump issue?
