I have a older 1980 hydro bass boat with a Evinrude 1985 90 HP out board motor. The other day I went out on the lake the motor cranked up everytime time until the end of the day. I tried to crank it, and nothing, no sound, and no turnover.
So luckliy after 20 mins of moveing the throttle lever up and down I finally got it started. While sitting at the boat ramp I decided to press my luck, and turned the motor offk, and it did it again. Luckly I managed to get it started once again using the same measure of before.
So I tried today I can't get it to turnover for nothing. Not even playing with the lever etc.
I'm thinking maybe a neutral safety switch may be bad. I opened the control box to have a look, and remove old grease and regrease.
I took some pics so maybe someone cold help me in maybe locating the problem.
I'm guesing the 2 yellow, and striped red wires are the two going to the safety switch is there anyway to bypass the switch to see if it is the problem?
Also what else should I check within this box or motor if it turns out the nuetral safety is ok?
Thanks Alot for any help
