motor won't turn up
seabassin
hey guys i just got a 1996 115 merc with supposedly a new powerhead (30 hrs). It had been sitting for a couple of years so i had carbs rebuilt first thing. When i took the boat out it will only turn 4000, (i had a 1995 100hp on before, and i used the same wheel). checked spark and have good fire on all cylinders, 130-135 compression on all four. when i pulled the plugs out they seemed to be drenched in oil. any good ideas
JUSTINTIME
Re: motor won't turn up
running a little rich
got the manual yet?
if not time to get one
Plainsman
Welcome to iboats!
I would also replace the impeller to be on the safe side. Good compression and good spark only leaves fuel.
j_martin
Recheck the last thing that's been changed. (Carbs)
seabassin
had carbs gone through again, by different mechanic, everything looked good. gonna put it in the water and try again.
