Motorguide Brute 756 with 12/24 switch
bcspanky
Hi I just purchased this trolling motor and need help with hooking it up I have no paper work with it. It has three wires Red, White, Black There is a 12/24 switch on the pedal, can this be run off one 12 volt battery on the 12 volt switch or do I need to buy another battery. How do I hook it up either way for 12 volt or 24 volt operation. thanks for any help. Bob
trumanlake
Re: Motorguide Brute 756 with 12/24 switch
It really doesn't matter which wire, red or the white, that you connect the + 12volts to. Motorguides standard wiring, to keep the switch decal correct, would be white +12v, red +24v.
