RoughFishAssassins
- Joined
- May 9, 2010
- 103
Hello all, I have a 2003 82lb thrust 24 volt tiller motorguide. THe issue I have is I was loosing power as we would troll. I was told it was more than likely the mother board. Well this troller doesn't have a "mother board" but has a module assembly. I replaced it and there is still a problem. It still seems to loose power and occasionally it will just cut out. If I let it sit for a few seconds and unplug then replug it it comes back to life, sometimes for a couple seconds sometimes for a long time. I have recently replaced the circuit breaker to a 60 amp manual reset type and that never trips. Now when I was replacing the module, I noticed that there are two relay looking boxes on the brush card, could that be where the problem is? I don't want to just be replacing parts till it works, and there really isnt much in them that could electronically go bad. Please help, I need this running good this weekend, I have a tournament and don't want to be loosing time messing with the troller. Thanks
