motorguide tracker 60
msman2008
To run this motor on 12 volt system, do you connect the white wire to ground,with the black wire connected to ground on the plug, the motor will run on the 12/24 volt selector switch on 24 volt only. It appears to be slower than normal. I am using a two wire plug.
