Motorguide Wireless W75 - does anyone happen to know where the antenna is for receiving the signals from the controls ?
Also, wondering if anyone happens to know if there is a service manual online anyway ? Or better yet maybe a web site about disassembling the motor ?
Yes, I understand it voids the warranty - just having some thoughts and am interested in finding this info.
Seems like you would just remove the bolts to disassemble the motor itself, but i would rather be 100% sure before i actually did something like that.
So why would i want to do that ? I have really bad interference with my sonar and I need to run a ground to my case. Due to the mount, running a wire down the column is not the easiest thing to do, at least neatly. So was thinking maybe i could run the wire down thru the column. I just put a new longer column on mine and it was really, really hard to get the old one off because of the sealant they use (yes, i used a heat gun). I doubt I could remove the new one without marring it up pretty good, so after seeing it about a Minn Kota, am thinking if i could disassemble the motor, I could run a wire down the column and then pull the wire thru the shaft....making a much neater installation of the ground wire.
The antenna - I have a 19' fish and ski. Apparently the remote is pretty much line of sight. When the back of my seat in the bow is up the signal does not reach the motor. Works better with the seat down, but even then if I am sitting in the helm, that seat is lower then the bow seat so the bow seat still gets in the way many times. Not normally a huge problem, but a couple of times I almost rammed a dock because I was cruising close, shooting under them, and when i hit the buttons it didn't see the signal.;
Not a definite yet, but was thinking maybe i could add a little external antenna. just thinking out loud.
thanks for any info
thanks for any info
