Motorguide wiring help
mfbear
Have 80's Brute 750, 12/24, 41# thrust with the large foot control, I picked up a newer control also 12/24 to switch out with large control. When I got into checking things out, I found that the old control along with the head and motor have 6 wires (Red, black, blue, yellow, white and green), the newer control has 5 wires (Red, black, blue, yellow, white). I have no idea what the green wire is for. I can not find a wiring diagram. Has anyone run across this before or have any ideas on how to wire in the newer control?
mfbear
Re: Motorguide wiring help
April 18, Well I figured out what the green wire does, it controls 3rd speed, without it hooked up it does not have full power. Not sure if the new control will work the same or not, guess I'll wire it up and check.
