Motors putting out 18 volts & not working right, HELP !!
Scali
Figured I'd start a new thread on this.<br />I accidently grounded the starter solonoid while tightening it couple days ago & had issues starting the boat after the incident { Motor's a '94 40 4 cyl }.<br />She would start, then nothing then bump over.<br />I thought it was the rectifier, changed it this morning then the same problems started happening also I believe I got a shock from the controls when trying to start it this morning.. I went to a marina had a meter put on battery while running & it's putting out up to 18 volts !!<br />Man, that cant be good, kid @ marina tells me it's the voltage regulator needs replacing, I agreed but I've been reading up on this motor in my Solec manual & it doesnt seem to have a voltage regulator ??? :confused: <br />Where do I go from here ?<br />Can it be the starter solonoid thats fried ?<br /> :confused: :confused: <br />Thanks for any help with this, I have a few more days off before starting a new job & the fluke are a biting.. Geeze , perfect timing
chuckz
Re: Motors putting out 18 volts & not working right, HELP !!
Where did you measure 18 volts? At the battery? If you have 18 volts at the rectifier you have a large voltage drop between it and the battery.<br /><br />Remove, clean and tighten the wiring between the battery and the engine. Include the wires to the starter. You have a high resistance connection someplace (high being a relative term). This would account for your high voltage reading and your intermittent starting problem.
Scali
Thanks for chiming in, 18 volts was read @ the battery..<br />On the positive stud on the starter solonoid, the backing nut { one closer to soloniod } doesnt tighten up, it's like stripped & keeps turning & turning..<br />So I think that component needs replaced for starters..<br />I'm going to pick one up today { hopefully if it's in stock @ Merc dealership near me } & take it from there.<br />Just wanted to add the starter clicks & when I press the choke that clicks so I dont believe I fried the neutral safty switch.<br />I was just working on it in the back yard on the muffs & starter engages one out of every 15 times I key it..<br />Man, 24 " fluke yesterday , why does this have to happen when the bite is on? :rolleyes:
Scali
LI Chuck, your post put me on the right track, I got the new starter soloniod & when removing the old one I had it basiclly fall apart in my hands { 11 yr. old motor I believe orig solinoid }.<br />Resistance is the word you used to jog my middle aged brain into remembering the other outboards I had with this same issue over the years. <br />Cables are good she bumps over like a new motor now, <br />thanks
Perfidiajoe
Where did they catch this fluke
Scali
Not they Bro, me.. ! :) <br />Sloop channel & Swift creek over by the bay houses.<br />Joe, I went out there today, spooled fresh 10 lb mono on my brass Penn ultrasport , tied a new Spro bucktail, got my spearing, ..<br />Went to Reynolds channel first , set up my first drift by 16 can got a hit then went to reposition for another drift, turned the key nothing but a little clicking noise.<br />Ahhhh mannn, took five minutes for this thing to bump over then I devoted the day on fixing it right & I think the old Mercs good to go.<br />Tommorow I'll get my doormat { I hope } LOL ;)
Perfidiajoe
If you have a bad sol. it was bad before you grounded it. If that is the problem, you can by pass to start in an emergency, just touch the 2 heavy cables together until it starts(with key on)which is what a sol. does, brings battery voltage to the starter wheh key is turned to start. As for the lock tite there are many types the one you need is a medium lock, it won't perminately lock nuts, they are still removeable, but won't vibrate loose. Now back to the fishing, maybe I'll sneak out tomorrow after work. Spearing & bucktail, Anyone using live killie & squid?
Scali
Not me with the killies & squid, people are using those baits, I think the squid is better for fluking in the ocean or if theres squid in the bays which I dont see too often..<br />I sometimes use a fluke bellie strip with the spearing but not too often also what I do is put 2 or 3 spearings on the hook, I dont like the bucktail to be too heavy with these other baits as it takes away from the way it bounces.<br />I believe the key to catch nice sized fluke is Spro bucktails with these Gamakatsu hooks, I like the 3 D look to the head also, they increase the hookup rate by 10 % easy just by foul hooking these fish as they ambush the bait .<br />I've got 5 fluke this year over 21 inches to 24 & 3 were foul hooked.<br />Back to the Merc,<br />what happened was when I put the wrench to this starter solonoid it broke the post inside the thing. I wont be doing that again, a little Loctite maybe or the liquid electrical tape & thats it. I noticed theres no lock washers on the rectifier, so I'm going to install a couple then stay out of the friggan electrical box @ least not when hungover after a holiday ..<br />I'm pretty sure I'm good to go though, I just have to see if I'm still getting putting out close to 18 volts tommorow, I'm going to boil my battery @ that rate, had to add some distilled water today about a pint. :eek: :)
chuckz
If you are still puttting out 18 volts, turn on some accessories. Drawing current should bring the voltage down.
bobrock
thats alot of long islanders....
Scali
Lets go Islanders ..Hey, whens hockey coming back,<br />I miss watching Nystrom & Billy Smith ..<br />Boat ran like a top , just came back from a low tide cruise for a couple hours.<br />Better then ever..<br />Thanks again LI Chuck, I didnt put a meter on it yet but hopefully it came down with these new parts I noticed I had the brightest stern light I've ever seen today, LOL
Moody Blue
Hey Scali, 18v is not uncommon in these motors when run at about 3000RPM and higher. I've got a voltmeter on my dash and it is alway up around 16-18v at planing speed. At idle I get between 13-15V. Because there is no regulator the voltage output is high. A good marine battery will tolerate the high voltage but an auto battery will not and you will boil the liquid out of it. I run the lights or bilge pump or what ever and the voltage drops down to normal range again. I to thought this was a problem but after some inquiries and talking with a few techs I found this to be the norm.
Scali
RodC I was hoping you'd catch this thread with an opinion.<br />Yes, I checked the search feature here on the site & came to the same conclusion that these 4 cylinder 40's { & 50's } put out higher voltage & it's OK when set up right..<br />Add this to the things a little unique to this engine, no thermostat, no voltage regulator,,
