mounting a bilge pump
ScottinAZ
ok, this is gonna come off as a stupid question, but Im gonna ask anyways.
What is the best way to mount a bilge pump to the hull?
Existing pump when I got the boat was just lying loose in the bilge, not attached to anything. No obvious mounting pad to screw down into either. I have a couple ideas, but wanted to see what the board thinks first. Im not really into the idea of screwing things directly to the hull, if y'all know what I mean
1) clean the hell out of, and fiberglass in a pad to the hull... Straightforward, but the engine creates a clearance issue.
2) weld (or bolt) a bracket to the front engine mount. How close to the hull is close enough for pickup before too much water accumulates?
As part of the rebuild process on my hull, I re-engineered the front engine mount. what was there was just a shedload of plywood glassed over and subsequently rotted out. (of course, thats what plywood does when it gets wet). I made some angle brackets (scavenged off an old trailer hitch) and welded a piece of channel steel between them that bridges between the sides of the bilge, and has full clearance underneath. only holes for mounting are above the level of the bilge, so if they get wet, I got bigger issues than wood rot. For those that will inevitably bring up engine alignment, It aligned beautifully for me, with no issues.
Clean the crap out of the hull bottom, some 3M VHB tape to hold it in place
L-shapped bracket attached to a bulkhead
airshot
Over the years I have made numerous pump brackets from a piece of aluminum sheet metal. Bilge pumps dont create any force, so it just needs to hold them in position at the deepest spot in your hull. Bend an angle in the sheetmetal arm to attach it to wherever. Screws, clamp, glue, tape, again no force from your pump to speak of.
