Mounting bracket compatibility question For Evinrude 77 70hp and 74 115hp
Bubbasboat
Would the mounting bracket holes for a 1977 Evinrude 70 hp model # 707739 line up with the existing holes on a hull which are from a 1974 115hp Starflite model #115493B, or would I need to drill mew holes and deal with he old holes?
jimmbo
Re: Mounting bracket compatibility question For Evinrude 77 70hp and 74 115hp
They will line up
boobie
Just make sure you get the motor height adjusted properly.
Bubbasboat
Is that an adjustment on the motor mount, or another adjustment?
boobie
No, it depends on what holes you use on the motor when you bolt it to the transom. The anti-ventilation plate should be flush or parallel with the bottom of the boat.
Bubbasboat
Thank You, that clarifies it nicely.
