KnotConnected
- Joined
- Aug 15, 2012
- 221
Well hey crew!
I'm replacing the trumpet horn on the foredeck of my '94 Cabrio 280. My plan is to modify the new horn so i can re-use the existing mounting brackets and won't have to fill the old holes and drill new ones, however I haven't had the new horn apart, so I'm not sure if that'll work out.
Questions:
1) What kind of sealant should I use for the screw holes to ensure they won't leak?
2) If I have to drill new holes, what should I seal the old ones with?
3) for the outside electrical connections that'll be somewhat exposed to the elements, is this sufficent, and if not what should i do?
a - Splice and solder the connections for the new horn to the existing wiring that I cut the old horn off of.
b - Seal with heat-shrink tubing.
c - Wrap neatly and tightly with electrical tape
Thanks all!
(Before and after pics to come!)
Questions:
Thanks all!
