Mounting motor
Bwalker
I just bought a new Yam 70 to mount on my new Duck boat. Any one have any tips a to how best accomplish this in regards to height, etc?
Dhadley
Re: Mounting motor
Your final X dimension depends on what prop (type & brand) you plan on using and how it reacts with that hull. If youre planning on using a standard Yamaha ss prop you can probably start with the AV plate about an inch up from the true bottom.
Bwalker
Re: Mounting motor
I plan on using a Yamaha aluminum prop. How will I know when the motor is mounted at the correct height?
Dhadley
Re: Mounting motor
Testing. If the rpms are too low and the prop doesnt vent, you can go higher. If the prop vents but the rpm is OK, you can go down slightly. If the rpm is too high, you can go to more pitch.<br /><br />If the rpms are where you want them and it doesnt vent, youre good to go. We have to find another excuse....er....reason to go boating.
Bwalker
Re: Mounting motor
I assume by vent you mean cavitate. Like what happens when you have the motor trimmed up to high.
JasonJ
Re: Mounting motor
Cavitation is when small air pockets develop at the propeller blade, becoming superheated, and causing actual damage (pitting) on the blade surface. Venting is when the propeller loses its bite in the water, two different animals...
