mounting nylon to boat hull
dutch420
Hey everyone I have a question I'm looking at mounting a piece of nylon to the transom of my boat to use it like a stern saver I do not want to screw into the transom so I'm looking for the best glue possible to hold the nylon to the boat I know stern saver product uses in an adhesive but I'm not sure what they use. I also know that stern server has holes drilled in the back of it to help hold the glue in pockets
H20Rat
3m 5200 fast cure... Just make sure it is exactly where you want it, you won't be removing the plate after a day or so.
airshot
Keep in mind if it does come off or if you choose to remove it, what will the glued surface look like? It may attack your glass transom. Another consideration is the fairly new double sided trim tape that auto makers use to attach emblems and trim pieces without screws. In the radio control world we call it servo tape and in nascar world they call it racing tape. Stuff sticks most anything and will come off with some elbow grease but it won't be easy. As long as you are not below the water line it should work fine. Look at a 5-6 yr old auto or truck and see how all the trim is still in place with just tape!
H20Rat
He is using the nylon plate to mount transducers, so it will absolutely be below the waterline. I don't think there is any tape out there that would stand up very long to being submerged.
dingbat
Never had any luck "gluing" anything to a boat. Bite the bullet and drill the two holes. Drill holes oversized and fill marine-Tex. Let sit overnight, drill and install with stainless hardware.
JoLin
+1.
fhhuber
You'll want to drill the nylon with a bunch of appx 1/2 depth holes to give glue more bite. No glue will hold well to nylon when it flexes, but you can improve your odds.
For smaller pieces I would say E-6000 craft glue because it sticks decently to fiberglass and nylon but can be rubbed off of the surface later. unfortunately the large area would possibly take years for it to completely cure since the solvent has to escape.
Epoxy would hold with the drilling, but as others noted you will have an epoxy coated transom.
The 3M gray auto trim tape (or any of the other ways they market the same gray foam tape) sticks OK to nylon but not as well as to other plastics... The ABS typical of auto trim pieces it does work well if you are sure to dewax/degrease the plastic to get the mold release off. Similarly you'd want to ensure there's no mold release agent left on nylon (or the fiberglass) for best results.
Best is to drill the transom.
Drill as if you were going to mount it... (you can go ahead and put in screws)
Pull the screws and the item being mounted off.
Drill the transom holes at least 1/4 inch oversize diameter. Epoxy in a dowel that is a loose fit in the hole. Drill and put the screws into the dowel to mount your device. You'll have an epoxy barrier to keep the water from migrating into the transom from the holes.
LeonWaldo
I would use a piece of King Starboard instead of Nylon and then get a 2 part epoxy adhesive from your favorite Marine supply store. Really though by the time you get the adhesive and look for a piece of the Starboard you minds well go over to Ebay and just buy the Hull Saver kit for $49. Good Luck!
Oh, I forgot to say that I work for a plastics company and we deal in a great deal of tapes and films so I have my head tape guy doing some recon for me to see if there may be a tape that can be submerged and would stick to HDPE - Fiberglass. I'll let you know on that one.
trailking82
I also recommend 3M 5200 fast cure. Position it exactly where you want, there is no easy second chances on moving it once its cured. If it were to come off it may take some of the Gel coat with it. I havent attached a transducer solely with 5200 but i have used it on my Pitot and it has held nicely for the last few years. Also used it to attach my Faria water temp sensor about 5 years ago, agian held nice but it see's minimal pressures anyway.
MRS
Just drill and put 5200 in the holes and on the screws and you will be good to go.
