mounting trolling motor on boat?
smsean
Does anybody know the basics on mounting a bowmount trolling motor on a fiberglass boat?Do you use some kind of backer under the lid or what?As far as electrical goes,what's the easiest way to wire it? It's a 40lb.thrust 12volt.I plan on using at least a 105amp deep cycle battery.any help would be great thanks!
norman158
Re: mounting trolling motor on boat?
when i put mine on i put a 1/4 inch aluminum plate under the deck and bolted through it too. i also used a seperate trolling battery. use good heavy wiring with a 50 amp breaker in the hot side
smsean
thanks norman! Do you think 8 gauge on the wiring is enough! :)
norman158
i think 8 guage should be good enough, i think i used 10 on mine but my battery is under the deck
its-a-sweater
GUNNY,<br /><br />AGREE WITH NORMAN. 8 SHOULD BE OK AS LONG AS THE BATTERY ISN'T MOUNTED 20 FEET AWAY. A PIECE OF PLYWOOD WORKS OK UNDER THE DECK. MAKE SURE YOU USE BIG WASHERS IF YOU USE WOOD.
smsean
thanx it's-a-sweater! Definitely need something to disperse load on the fiberglass!Good idea! Battery will probably end up about 3-4ft away.Trying to keep it close.Pressed for room on where to put it.Should of got a fish-n-ski that was set up for it!
harrison20002
Happy New Year Gunny, With 3 to 4 feet distance from your trolling motor Eight ga. wire is plenty big. Good luck with your mounting chore. Norman158 is right on with the aluminum plate under the deck. Happy Boating. Hal
smsean
thanks for the insight hal! Must be pretty nice in california this time of the year! We had a high of 28 degrees today in upstate ny.BRRRRRRRRR.Wish I was fishing though!Oh well It'll be May before you know it...
