Re: Mounting Two 83/200 kHz & 50/200 kHz Transducer
i would put one on the transom and one on the trolling motor..... use the transom one for driving the boat and finding structure as you move then when you get up to fish just switch it to the one mounted to the troller and you read what you are going over right then and not what you went over 20' ago.
the only thing is you need to locate the head so you can see it from anywhere in the boat.
