Moved motor from ski boat to pontoon what prop should i change to???
danemaker
I just switched my yamaha 90 from a 16' ski boat to my 18' pontoon. Now at wot I only get 3500 rpm and 20 mph. The prop on the motor is solas 3411-135. Im very unsure of the correct prop to replace with. Any help is greatly appreciated
Scott06
Not sure what the recommended wot rpm of your engine is. Would assume 5500
Or so I think based on the fact your current prop is a 15” pitch you need like a 9” pitch, which is really low. You may need a different gear case to push a pontoon as based of the numbers given I don’t think you can get a pitch low enough …
danemaker
Yikes gear case is way out of my price range. I dont really need optimal performance just the best i can get on a budget.
jimmbo
Keeping the Engine from dying a horrible Twitching Death is why it needs to be running in the correct rpm range. What rpms were you getting when it was on the 16ft?
danemaker
I couldnt keep the boat from jumping to run wot. but I could easily hit 5000 rpms
flashback
Might work but I would think a 9 would raise it 1200 rpm or so vs current 15” … still too low and lugging
I agree. He needs to find a prop shop that will work with him.. I have one, I pay a fair price but he lets me exchange if needed.
