I read in a thread KennyB referring to a great advantage from adding a jackplate with 6" set-back. I am about to go ahead building my 17' runabout and would like to reach a good setup with my 115 Evin. I have the possibility of building a 10 gal tank in the rear between the mid stringers, as there are only two in rear. This would move center of gravity back, maybe similar to getting some set-back. Is the benefit from distributing weight back - or from what ?<br /><br />Will placing as much weight in back of boat gain speed ? The hull is a 17', 6,5 Beam ind the middle, 5,5' at transom.
