They are part/casting #'s 14034A3 (starboard) and 14035A3 (port) off an Alpha 1, the cylinders measure 16-3/16"
One problem though, the extended length is 27.5" between the pins which I think is 3/4" longer than the original 45706A14 which had cylinders that are 14-7/8"
Ayuh,.... My new knowledge for today,.... I never discovered this fact before,.....
Maybe a later longer lower pin,....
Probably better than grindin' some room on the ram, 'n gimbel ring,....
Though, those rams are round in the workin's inside,...
Some of the squareness, 'n flare on the bottom could be relieved abit, as well as the gimbel ring,...
Probably a good idea to get in the habit of not goin'
Full up, but instead just mostly up,....
Like I said, ain't been here before,... swapped in the other direction,....
