MR outdrive - no reverse after changing lower shift cable
boozer1966
Replaced lower shift cable. Now can’t get into reverse. Any ideas of what to look for? I dread having to pull the drive again.
Bt Doctur
Did you install the cable fully seated in the housing. cant have more than 2 threads visable
dubs283
Drive won't achieve reverse or the engine dies when shifting reverse?
Does you properly adjust new lower shift cable?
boozer1966
Yes. No reverse and engine dies when shifting into reverse. Even with the cable disconnected from the shift plate I cannot get reverse.
dubs283
Cool, the drive is installed correctly because you don't want to r & r it
You can't achieve reverse when you cheat it let alone as designed.
The cables are installed/adjusted accordingly
Mod Edit:
Attacks on another member will not be tolerated. See Rule #4
Bt Doctur
Well then, if you had the control box in full fwd and the drive in full fwd when you installed the drive then youmissed the roller in the slide or improperly installed the cable or improperly adjusted the cable
boozer1966
The drive cannot come off because it's the end of the boating world for you. Dreadful
Time to sell your boat
Thanks for the load of sarcasm. Very helpful.
boozer1966
And for those of you looking for actual advice and help as opposed to the “admiral’s” self-aggrandizing pay on the back, check the condition of the roller that slides into the shift fork on the cable when re-installing the outdrive.
ROY WILLIAMS
the shift cable is fwd drive the barrel and the post is the 6 inches ..
look up the shift cable of the youtube ..
