I've got two MR out-drives complete and was thinking about hanging them and sand blasting and painting them. One has no corrosion at all the other does from being in a slip. Any thing I should cover, tape, or take off before I blast? thanks, Chris
The aluminum is to soft. There is no way to get all of the particals that are impregnated into the aluminum.
You should NOT sand blast them. and Never sand blast the inside of any aluminum gear housing. The aluminum is to soft. There is no way to get all of the particals that are impregnated into the aluminum. But running the drive will loosen them up and destroy the drive.
Thanks for all the great advise, I'm glad I ran this threw Iboats first. I'll have my alum primer in hand before I wire wheel and clean the outdrives. Thanks again. Chris. That mr drive looks auwsome.......
If someone was going to charge ,me $500.00 for the job I did, I would have let them do it for that price
I get the protection of paint for about a Buck, 2.98....
And, it takes a Whole 10 minutes....
Exactly. Plus, if you make it too pretty you get afraid to use it!
