sparkroost
- Joined
- Mar 23, 2003
- 312
115393M 115hp evinrude.<br /><br />I have not kept track of hours on the motor since rebuild, but have kept track of fuel used. Is there a magic number to look for is fuel consumption?<br /><br />I am having a problem with out of water idle at 1200, but in water goes to 700-800. If I set the muff idle at 1000 pr. manual I am getting around 500 rpm. Once warmed up the engine will idle at 500-600 without stalling. also.. I have the idle adjustment screw all the way in. I have set the link and synk set to 5 deg at the center of the roller and the slash mark on the cam. I do have some wear in the throttle shaft where I can see the butterly slightly rocking up on the actuator side. low, mid range, and high end are very smooth running with no heavy shaking. At idle there is a little shake every now and then.<br /><br />Why do I have to have the idle screw in all the way(1200 rpm).. also.. if I give slight throttle the cam is moving the roller which is giving excess throttle and the engine will want to raise in rpm dramatically(say from 800 to 1200, I am recalling from memory)... example. If in reverse at 700 then I want to get it to 800-900, it may go right to 1000, then I am too fast in reverse.<br /><br />Plz keep in mind this is with a 24:1 mixture, but I dont think this is contributing to my problem to a degree that will change significantly once I goto 50:1.<br /><br />Any help would be appreciated.<br /><br />P.S. compression is at 150-152 pr. cylinder, new coils, wires and champ Ql77JC4 plugs set at .040.
