This is more of a question of whether muff testing will verify if you have a water intrusion problem than necessarily telling you what kind of water intrusion you have.
But after I've inspected risers, manifolds etc etc- and I want to be confident I don't still have water coming in anywhere else- Can I just run the motor on muffs up to temperature then shut down with the water still going on the muffs and then open the plugs, crank the motor and if no water comes out- is that a good indication that I won't have water inflitration when I put it on the water? If the engine runs and starts smooth, compression is good and oil is clear- is muff running a good enough test ?
Or can manifolds behave quite differently when you're actually on the water boating vs just running up to temp at idle and shutting down while still on the muffs?
I'm assuming that it's a lot better and less stressful to the engine to find out you have water in the cylinders by pulling the plugs and cranking - than trying to start a hydrolocked motor.
Lastly can an engine hydrolock when it's up to speed at high RPM or is hydrolock something that only occurs when trying to start an engine back up? The idea of hydrolocking at high RPM gives me shivers... Never happened to me. The torque from the starter motor is one thing - the torque/inertia involved with a motor running at high RPM scares the crap out of me. Just want to know if it's possible. If so maybe I'll do a little more tear down than just running it one more time on the muffs. I've already inspected my riser/manifolds and it looks reall good and I'm beginning to think water just got in their thru my carb because it wasn't covered with plastic and we had some thunderstorms and downpours while it was in "dry" storage. I'm hesitant to pull more stuff apart if a muff test is a good indication if I still have any water issues.
