GSX455
- Joined
- Aug 21, 2016
- 165
Newbie problems, still. My stringer template was a little off; I have a gap I can just slide my pinky (1/4") under about only 6" of the length of the stringer towards the bow. The rest of the stringer sits flush. Re-do the stringer or will extra epoxy PB work for larger gap filling? I chose epoxy as this is stronger than vinyl ester.
The other question is if I see fiberglass cloth, stop sanding? All old tabbing was removed until I saw green resin, or saw cloth.
My stringer needed the sides chamfered to fit in the V groove. Is the green color epoxy or is this still polyester? I plan on using 1708 with epoxy to make the tabs for the stringers, or do I use 18 oz fabric based on the how-to from woodonglass?
I just want to make sure this is good before going forward.
Thank you for any advice.
