I'm trying to save a Neptune 10A2, c. 1940.
The piston is frozen in the cylinder. I believe from neglect and rust and not from scoring.
The connecting rod and crank are in good shape.
I have the cylinder flooded with PB Blaster, soaking.
Is there anything else I can try to loosen the piston?
It appears the piston is aluminum, the cylinder walls are cast iron, and the piston rings are steel, so I think the rings are stuck to the cylinder.
And, while we're here, is there a source for seals and gaskets, etc.?
Thanks,
J
Thanks,
J
