MUSCLE CARS
denniz
I cant be the only one... WHOS Got one and what is it? I m building a 68 AMX, 390 auto. Any way to post pics?
NewbieBoater
Re: MUSCLE CARS
Rod Knocking,<br /> Yep I own one. She's a 98 Vortech Supercharged Mustang GT. Here is a picture of the engine (it's a little 4.6):<br /><br />
denniz
Re: MUSCLE CARS
TURBO? Nice.. How do I add that on.???? Ive checked out a few turbo sites and its all New stuff. Got any ideas? sites ???? cant be that hard to retro a older engine. (Can it?) I have that same motor (stock) in my 4x4 97xtd.Man it could use a kick in tha asz too. What you runnin?
NewbieBoater
Re: MUSCLE CARS
Rod Knocking,<br /> Well this post is going to be long (grab a beer or something). I bought this car new and the "addiction" started early. First it was the exhaust, then shifter and ..... the list continued on and on.<br /><br /> The car currently has the following modifications which I did myself in my litte garage with small craftsman tools/compressor(listed in no particular order and very extensive):<br /><br /> R470W 4 speed automatic, performance automatic custom valve body & deep trans pan, Hayden trans cooler, 2800 Precision Industries stall converter, Vortech "S" trim supercharger w/Reichard racing pulley, Bullitt intake, Cobra twin 52mm Throttle Body, D&D Coilovers, Maximum Motorsport Caster/Camber plates, Lakewood 90/10 struts/Lakewood 50/50 shocks, AFM 4" PowerPipe, FMS Alum Driveshaft, 42 # injectors, Walbro 255 intank fuel pump, Walbro 255 inline fuel pump, Steeda Heavy Duty Upper & Lower Control Arms, Steeda Full Length Subframes w/cross-brace, Cobra R 2 1/2" cowl hood, HPM (Zinc) driveshaft loop, MSD DIS-4 digital ignition, Pro M 80mm Mass Air Meter, K&N Air Filter, Weld Prostar drag welds, 31 spline Moser hardened axles, 3" Moroso studs, McGuard lugnuts, SVO differential, "Downs" rear Girdle, FMS 3.73 gears, 180 deg thermostat, Fan by-pass switch, FR500 Steering Wheel, Phantom white gauges throughout car, Mac longtube headers, Mac offroad "H" pipe & Borla XR1 catback.<br /><br />As for your questions, I bought my supercharger from: http://www.vortechsuperchargers.com <--- Vortech site and you can see if they offer it for your car. I'm currently running between 12-14 pounds of boost.<br /><br />No idea what the car will run right now, it's strictly a street car and have too many broken parts from drag strip. I've swapped the car from a 5 speed to built automatic and various other things like pulling the blown up 98 engine and going with a better 2k iron/windsor block.<br /><br />Here's an older picture of the car, however, it gives you an idea of the front/back tires/rims that I'm running:<br /><br />
<br /><br />Here's a dyno with my old engine (I've since swapped engines and went to a more wild setup that I've listed above). Keep in mind that the dyno reflects rear wheel horsepower and not flywheel:<br /><br />
<br /><br />Here's what the inside custom gauges I've done look like:<br /><br />
<br /><br />Here is a picture of what happened to my last engine after shoving too much boost in it:<br /><br />
<br /><br />Let me know if you have further questions. By the way, my sister used to own a Javelin... loved that car and wished she would have kept it :D <br /><br />Cheers,<br /> Tim
NewbieBoater
Re: MUSCLE CARS
By the way, here's a newer picture of the car (tried out my new zaino wax stuff):<br /><br />
<br /><br />-Tim
denniz
Re: MUSCLE CARS
Very Sweet. The guages look great My prb is since ive went to a smaller steering wheel I can see the guages while Im thrown back in the seat guess I need to run some under the dash to keep up with it. Awesome car. Whats it run in 1/4? or is it a roadracer? Im running 295/50 15s on the back of mine now.next is smaller tires, intake and cam. TURBO would be great!!!!
NewbieBoater
Re: MUSCLE CARS
Last run at the track (almost 2 years ago) with more mild setup (different engine, trans, suspension) and full street setup/full tank of gas (street tires 245/45/17 with 17x9 rims) it ran 12.6@113mph :) The setup I currently have should run much better I'm thinking mid 11's around 120'ish.
denniz
Re: MUSCLE CARS
Awesome mine supposively was 140 mph from the factory.25 years later its hard to run it at that with stock suspension prob 13's in the quarter. I heard THUMPER ran a 14 but its a AMX set up for road racing top speed 180.
Carphunter
Re: MUSCLE CARS
Ok newbieboater, the car looks great, but i'm more interested in where the picture was taken,.........looks like some good huntin.<br /><br />mmmmmmmmmmmm..........huntin. :D
ehenry
Re: MUSCLE CARS
Did someone say muscle car???? I have what use to be defined as a muscle car ie: 1967 Chevelle Super Sport 396. Granted its not computer controlled fuel injection with a super charger and such.....BUT....she'll still pound the ground leaving positive traction marks on the road farther than a man can jump through all 4 gears of the Muncie M22 close ratio transmission w/a 373 gear in the rear end. I only get her out on special occasions now. I've had her since 1972 and she was my main mode of transportation until 1986 when I regained my interest in boating, fishing and hunting and such. I retired her for restoration which is complete now...I'll post pics from computer at home later.
ob
Re: MUSCLE CARS
Sounds sweet efhenry.Son and I just recently parted with a 1972 chevelle 454 4bbl w/ 352 gear in a 12 bolt posi rear and turbo 350 tranny.We miss it.Hope to get another project car soon.I really like the 67's.
ehenry
Re: MUSCLE CARS
My boy drools everytime I get my car out. He's 15 and just got his license and thinks I'm going to turn him loose in that car......Boy howdy is he wrong ! ! ! ! I've turned him loose in the 86 Toyota 4x4 that I bought new when I started hunting and fishing again. I told him to look at it this way.......A ragedy ride is better than a dressed up walk any day. Besides the Toyota is in excellent shape. The air still blows cold, its got a fresh engine in it, just had the interior redone. All that just for him!!
SpinnerBait_Nut
Re: MUSCLE CARS
Yea EF and OB, your talking real muscle cars now.<br /><br />I have a '64 Camino with a 30 over 350 in it with a 350 turbo tranny and 6 cyl. rear end.<br />You talking bout fast.<br />Special made the drive-shaft to fit the 6 cyl. standard rear end, but it works good.<br /><br />Yea them are the real muscle cars.
ob
Re: MUSCLE CARS
I heard that EF.Turning a young teen loose in a restored classic unless he partook in the blood sweat and tears of the restoration and maintenance is like letting someone tap dance on a Duncan Phife table.Ironically ,my son now drives the 85' 4WD Toyota pickup I bought new in 85'.<br /><br />Nice sounding ride SBN.
SpinnerBait_Nut
Re: MUSCLE CARS
Yea ob, I traded a ol motorcycle for it straight up.<br /><br />They had rebuilt a 327 with some 202 heads and had cut off the breather pipe that runs down the back of the engine and had drove a dow rod up into it and blowed all the seals out of it so I had this built 350 and auto, so I just pulled the 327 and 4 speed out and dropped it in there.<br /><br />Now this winter, I am doing a complete frame off and going back with the white on white paint.
mellowyellow
Re: MUSCLE CARS
owned a '70 Challenger 383 magnum R/T for a few years.<br />factory Hurst 4sp, she was a rocket!<br />late 60's, early 70's cars rule!!!!<br />kinda like outboards... like to run at WOT :cool: <br />the 68 AMX is a sweet project dude.<br />post some pics. if u can...<br />enjoy,<br />M.Y.
ob
Re: MUSCLE CARS
SBN,Sounds like a fun project for us little boys that still like to scuff knuckles and get sweaty and then admire our toys.
mellowyellow
Re: MUSCLE CARS
hey EF!<br />the '67 chevelle (last year of the long body)<br />is in my top 5 fav. cars. bought one from the<br />origional owner in Long Beach 15 yrs ago. no<br />rust or body repairs, interior 100% perfect, <br />cept the stitching in headliner was rotted and<br />giving out... origonal perfect carpet with the<br />1 piece factory platic mat. only blemish, her <br />kids had her car painted as a gift. :eek: <br />weren't no SS, just plain 283 auto, but what lines!<br />anyways... sitting on my couch one night watchin<br />the tube, I hear the un-mistakeable sound of my<br />283 startin up out front. I jump up as the car<br />drives away. we mount a search party of 3 cars <br />and go looking... nothin! she's gone!!! :mad: <br />I got lucky and my young wife at the time agreed<br />to drive her. we had no $, and was the only way<br />to keep my toy since I drove rediculous miles each<br />week... so she goes out and buys herself a Honda :rolleyes: <br />outa the blue, 6 months later, I get a call from<br />the impound yard... they have my car and I can have<br />it back for $300. drove her hard for a week and <br />and sold her :(
denniz
Re: MUSCLE CARS
Hey Mellow Yellow I owed a 340CUDA (TWICE) came with a stock 340 second time I bought it had a 383. Think it ran better with the 340. Rockets no doubt. I can email pics if anybodys hosting.Thanx
NewbieBoater
Re: MUSCLE CARS
I agree with everyone above. The definition of "Muscle" cars is more geared towards the older cars like the older Mustang, Camaro, Chevelle, Nova, Hemi Cuda, Dodge Charger/challenger, etc, etc, etc, etc,..... <br /><br />I'd love to have a Hemi Cuda... my neighbor pulls his out once a month to tease me and all the other hot rod folks :)
