My 15hp outboard is having problems engaging reverse.
Brett Man
:grumpy: I have a 15hp Nissan and sometime I have to put it in neutral and rotate the prop a bit to get it to go in reverse. The bevel gear is not lining up with the clutch all the time so I have to turn the prop a little for the clutch to engage. It always goes into forward no problem. Any advise?
tohatsu9.9guy
Re: My 15hp outboard is having problems engaging reverse.
linkage needs adjusting or something is causing it to bind or not be able to move the full distance it needs to, clutch dog needs replaced?
TOHATSU GURU
Are you shifting it when the engine is not running? They are not designed to be shifted unless the engine IS running.
tohatsu9.9guy
true, didn't think of that. I don't see how you'd reach down and spin the prop, shift at the same time, and manage to keep your fingers if the engine was running.. surely his problems are when not running. Start that baby up and it'll work right!
Sea Rider
If shifting testing while engine is off, turn flywheel CW while shifting. Remove safty lanyard as engine could start....
Happy Boating
pvanv
It's normal. As Elvin noted, the motor must be running to shift, especially into Reverse.
