My 1968 6 horse Johnson kicker
BUDSMITH
is making one hell of a mess to the back of my Tyee. See pics and comment please...........
Oily residue is coming out of hole in the bottom of motor...........
BUDSMITH
Re: My 1968 6 horse Johnson kicker
another pic
Al-53
That looks like unburned oil....you may be running rich...
Al
Daviet
Are you missing a bolt that holds the power head on? I don't think there should be any kind of leakage in that area.
BUDSMITH
Yep----------Missing a bolt:confused:
will find one..Thanks a Bunch
BigB9000
If you were missing the bolt to the right (middle bolt) It would be leaking water ;)
Keep that in mind if you ever want to drain the water out of the powerhead. (like salt water)
jtexas
looks like more than just a bolt missing -- bet there's an interesting story in here somewhere...
BigB9000
I doubt its any more that a bolt. With that bolt missing, you have a hole leading into the exhaust area.
This is one of the best place to have a broken bolt/threads.
If you had to, you could pull the exhaust port and get to the top of the bolt, and throw a nut on it.
BUDSMITH
I went to store and bought allen head bolt, red loc tite and installed. Bolt fit snug so I think it is fixed.
May have been a little rich and hole was in exhaust so------there we have it. Will get on water this weekend and give it a try. :):):)
Thanks Again---Bud
1946Zephyr
You used locktite?:eek::eek:
Good luck getting it out again, should you ever need too:(
BUDSMITH
Loc tie is not that good, I use it all the time on my Harley, with no adverse affect. I can still remove bolts if need arises........
Bud
