Bonaventure
- Joined
- Jul 3, 2016
- 167
I bought this engine a couple of years ago and used it last season for about 30 hours. It is not too good looking cosmetically. I was scared that it needed a lot of work, lower unit etc. I even approached my wife about a new Suzuki. This afternoon I removed the filler plug and sure enough, there was a lot of water in it. I removed the propeller and the front piece of the lower unit that holds the prop shaft. The gears are like new and there seemed to be some oil left right around the gear bearing area. Then I did a compression test. I have a screw in type compression gage.
So I went in and said to my wife, I am not going to buy a new motor. The compression read 120 pounds. Cold.
So I am going to rebuild the carburetor, water pump, lower unit, put in electronics ignition, new coil and all.
I would have been happy with 80 pounds of compression!
