Bannister 6905
- Joined
- Jun 5, 2015
- 110
Motor - 1992 Mariner 90ELPTO S/N OD130152
Up until a recent trip to MN, the boat has run well, with no issues. During the trip, I drove through a deluge and apparently water got into the fuel, which caused the motor to run poorly. I eventually drained the tank and refilled with known good gas, but the running issues continued. The symptom was stalling after being underway for a short time. Afterwards, the motor would start up, but was difficult to keep running
Symptoms - hard to start, as if the motor is starving for fuel. Once running (rough), it gradually slows to running on one cylinder and then stops. It will not accelerate while in the water above a fast idle, and eventually dies again.
The strange thing is that it runs pretty well (although a bit rough) on the hose in the driveway, never stalls and seems to accelerate up to 2000rpm with no problem. On those occasions when the motor starts to slow down when on the hose, I spray carb cleaner into #2 or #3 carb intake and the motor picks right back up - it often just keeps on running well after that.
Aside from replacing the fuel, I have done these things:
new fuel lines
rebuilt fuel pump
new plugs
new filter
removed and cleaned carbs twice - they are clean
replaced intake carb gaskets
checked for leaks around carb shafts, hoses, fittings - sprayed with carb cleaner with no effect.
new 16A stator (old one was failing tests)
confirmed all 3 cylinders are firing when motor dies (by timing light)
checked for "spitting" from carb intakes - nothing (reeds)
compression reads 120 / 120 /115 - motor warm, throttle wide open
trigger tests OK
rebuilt water pump - strong stream and motor runs at normal temp when on the hose. Strong stream when in the lake, as well.
On both occasions when I removed the carbs for cleaning, all 3 had fuel in the float bowls and the floats did not appear to be sticking and there were no restrictions in the lines or elbows feeding the carbs from the fuel pump and between the carbs.
When on the water, the only way to get the motor to even go a bit is to depress the primer on the key switch, which allows the motor to speed up a bit, but it will not plane the boat (17' Fisher aluminum) and quickly dies. During this time, the primer bulb remains hard. Pumping the bulb has no effect on the motor stalling.
I've know of reached a stalemate with the motor and am out of ideas as to what the cause might be. Any suggestions would be appreciated.
Thanks.
Bannister
new fuel lines
rebuilt fuel pump
new plugs
new filter
trigger tests OK
Thanks.
Bannister
