Yes its is am90a i cleaned the carbs twice and filter, yesterday it rev higher but it was like a car with rev limit at full thro it da-da-da-da- if that makes sense than thro back and its wont rev up again.I take it you have an old M90A? Did you check for a spun prop? When was the last carb cleaning? When was it last checked for proper link and sync? Is the fuel filter clean? If this seems daunting to you, see a dealer.
Ok i will soak them again, How do you you check proper link and sync.Did you clean the carbs by soaking them for 4 hours in carb dip? If not, start there. Also check link and sync.
Had wife drive boat at full thro and i put a rag over each carbs and the bottom one rev up boat, so im going to soak carb again hope this works i soaked that one all night and day.Full sync info is in the Factory service manual; trying to describe it on the forum would be difficult.
Yes i took bottom carb apart and found float was full of gas, Just order rebuild kit But i dont understand y if i put rag over carb rpm go up i thank it should be flooding? i bought the gallon can cleaner and blowed compress air thru and carb cleaner.What did you use for carb dip? Did you blow out the soaked carb with carb spray?
yes i just rebuilded the carbs yesterday a little better but the bottom carb still starving for fuel i only thing ive not done is replaced fuel pump?If choking with a rag helped, you were not delivering enough fuel, so it was not flooding, but rather starving for fuel.
Possible. If it seems to "run out of gas" after a few minutes at WOT, you might be delivering insufficient fuel. I would check it per the manual.
Yes i put a new fuel pump on and still same i took choke link off bottom carb and zipped tied it close, it and got 4 more MPH, but cant get WOT because it like it got REV limiter on it, its going Da-da-da-da-da. are still starving for fuel, going back in carb today and clean itClean the carbs again and again and again..............and again.
